Elisha Nichols
- Joined
- 19 May 2023
- Messages
- 19
- Reaction score
- 7
Hi there, I'm half way through my a-level now and have completed a MDF mock up of my project. I have taken those who replied to my originals posts ideas into consideration, as well as my clients opinions too.
Here is the MDF mock up, i would appreciate your opinions and criticism on it and any improvements or changes you think i should make. Are there any materials you think this would be ideal to make in, and finally if this was a real product would you buy it?
Here is some context for those who don't know, I have made a jig that aims to make the process of cutting veneers on a band saw (on the right hand side of the table, where the miter track sits) much easier.
The jig sits in the miter track, and has a dial in the middle that allows you to cut 1mm-8mm veneers, I also have another dial that sets to 1.5mm-8.5mm, 0 is included in both. the idea is there's 2 slabs of MDF sat on top of each other, but they can slide and move back and forth, away and towards the blade.
You spin the dial round to the desired veneer thickness and then when you push your wood to the jig aligned with the blade, you bring your fence to the other side of the wood and clamp it down, then slide the top layer of the jig back so its not in the way of the blade. AS the dial doesn't change (unless you change it) you can easily slide the top layer of the jig back to the blade and set up for your next veneer.
