Wow, what fantastic responses, thanks all, will try and get through all of them:
- Are the boards cut with good square edges? Yup, cut with plunge saw/guide rail and I’m now in the habit of triple checking measurements/square. I’m satisfied the boards themselves are true.
- Knowing the pocket holes screws like to move the piece slightly, my method up to now has been to countersink a pair of screws out the outer face at the top and bottom of where it meets the next board i.e. so I have more control that where the boards meet they are aligned. After they are in I then go around screwing in the pocket holes (using the kreg ones with pan head). Although I’m face palming as Roy’s comment about the Kreg clamp reminded me that I had bought a pair of these last month and they were just sitting on the floor unused.
- I did not measure the diagonals of the carcass. In fact in my novice/amateur approach, I failed to even check a single corner was a 90 degree. In assembly I had put on quick corner clamps, took the view that if the boards were right and the corner clamps were on, then obviously the carcass would be right but clearly that was my fatal error.
- Re the base/plinth, yup that has been triple checked, I am happy in every direction including diagonal that it is level (and have checked the levels themselves). The gap on the right hand side is to scribe an infill piece, I aligned it flush to the left hand wall as will then scribe an infill piece to the chimney breast i.e. scribes on both sides if that makes sense
- Lol that made me giggle…that’s not my main square a recent acquisition (a set of 8) to use along with clamps during assembly of things but in this instance I used Wolfcraft corner clamps which I won’t be doing again. I suspect that the first piece I attached must have come in at a minute angle, which when replicated for the other three corners means the whole thing has a lean that become noticeable at its length. Novice/amateur error no2… I made a squared back panel didn’t I…. put on the carcass and…well…it didn’t line up. No matter how I positioned it, one corner had too much and another not enough etc. Did I dare question the carcass at this stage? Nope… assumed I’d cut the back wrong and flush cut the overhang with the palm router. All that said, I’ve never spent more than a tenner on a square so today’s purchase will be rectifying that. Also as per the suggestion, I think making longer squares with cutouts might help going forward as a way to clamp during assembly.
- Re bracing/racking, this lower carcass is for drawers and then I will put another narrower carcass (long story) on top for a hanging rail. Where the 2x 18mm MR MDF meet will be covered with a similar size 21mm thick Redwood face frame. Additionally, I’ll gripfill the gap most of the height from the carcass to the right hand wall and then put a few nails between the carcass into that piece once it’s gone off to give it more vertical support. You’ve now got me thinking, as it’s quite a wide piece, to also scribe and fill the small horizontal gap at the back of the carcass to really wedge it into place etc
In summary, I’ve made some significant errors but bloody glad I’ve identified them so early in the project. In regards to remedying this current carcass, should I get the hammer out and knock the back off, then disassemble the carcass and start again? (my concerns would be the screws would just find their original holes although might be ok with a much better clamping job. Or as suggested, should I maybe screw the bottom of the carcass into the plinth to give it a footing, then try and “twist” the front true by screwing into the right hand wall?
Once again… honestly and genuinely, thank you all for your help, was the end of a tough week yday and could feel the stress demons approaching. Feel a lot better about going back out there now.
