What Generator To Buy
niall Y
1 Nov 2018
CARDIGAN
Having been without electricity for 2 1/2 days directly after Storm Darragh ( and for a further day after that). We have finally decided to invest in a generator of sorts. The minimum it will need to do is protect the contents of the freezers,. and allow us to charge up the phones, without which we would be stymied Nothing as high usage as a washing machine or electric kettle.
I'm wondering which models and makes have proved most useful and reliable for other members of this forum. And which ones they would recommend.
You c a n spend anything from a couple of hundred to a few thousand. The more expensive ones will run continuously while the cheaper ones are for intermittent use. As well as the output you will need to consider noise levels as several days without electricity is bad news but a neighbour’s loud generator on top of no electricity may add further discomfort unless you live on a farm . With that said if I was in your position I’d buy ghe biggest and best that I could afford . Protection for freezers is important but so is boiling a kettle or even a temporary water heater ( baby burco ) or similar and then there is your heating concerns .. imo ..
Sound - as already said - and also the way it makes A.C. I think some are safer than others with electronics if that's likely to be an issue
Length of tank lasting (assuming you do not want to get up every 2 hours for a top-up)
Ease of maintenance?
Fuel storage - especially the modern contaminated stuff that goes off or worse very quickly.
Honda would be my go-to for smaller stuff, maybe Hyundai for larger. But one other question - how often do you think you'll need it?
One extra to consider is how, when, where and for how long will it be left stored. Whether cheap or expensive, keeping it maintained when not used is crucial.
I have a 3kw wolf gen, petrol a tank will last 6 to 8 hours
I have to have mains power, used to live really close to the sea. In storms we would get flooding the sub station is still less than 50 mtrs from the sea
I invested in the gen set and later self fix solar panels
I have a crappy Wolf 1200.
Can run a few lamps off it, but it struggles to boil a kettle...
However, I now power it with Aspen rather than petrol, after great success running my Webb mower on it.
Pricey, true, but invariably starts first time...
How are you going to use the generator to power freezers etc ? - with extension leads or getting its feed connected into your consumer unit with isolating switches to change from mains to generator?
I managed to blow up a television with a generator some years ago . . .
Thanks, one and all for your replies.
As we have bottled gas, then boiling a kettle isn't a problem. We also have an oil fired Rayburn. So we do have a few other options when the power goes off. And, as far as noise levels go, we are a field away from our nearest neighbours.
I am thinking that 3kw output would be about right for our needs. This, with a Hyundai, would be in the region of £500. Anything at the next higher output, seems to be weighing in at about £750,
A friend and neighbour has also recommended a Honda but to obtain the 3KW output seems, on first investigation, to be costing £1,000. So, there is going to have to be a real balancing act between output, cost and reliability.
At the current rate of power cuts, we are going to be using it about 4 times a year, concentrated, mainly, over the winter period. And, if these bad storms are our new reality, then this rate can only increase. ( I believe another one is forecast the week before Christmas )
I take on board what has been said about running a petrol generator on something like Aspen which should minimise running problems , due to the generator only being used intermittently. Problems, I already experience with getting the lawn mower running again, after the winter months.
Niall
put a good quality extension lead on the Gennie and plug whatever you need into that. Pop down to your local Machine Mart and tell then what you need to power and they will suggest the best one for your needs. Pity, you have just missed a price crash as well.
