Lons":31a1cl8l said:
I think that's part of it myself, and I had initially said something to that effect but edited it out.
Obviously there's plenty of good word of mouth too but it was fairly obvious (to me at least :-" ) that much of that was the enthusiasm of early adopters, "Best thing since sliced bread!" And we all know that tends to get tempered over time.
Out of interest which other brands.
Chestnut, Blackfriar, Johnstone's, Ronseal, Liberon, Mylands, Treatex.
I've never used poly oil and always just the old ways of sanding sealer, danish oil, varnish, wax etc.
Which there's nothing wrong with in 90-95% of cases.
The subject of what finishes you should have in your arsenal gets brought up a lot now in the days of Internet discussions and many of the pros, writing for their largely amateur reader base, suggest that people keep it simple and stick to just three core finishes, master them and use them for
nearly everything.
Anyway, you've bought already but if this were mine I'd have been tempted to try one of two finishes, a pale shellac or soap. Both meet your requirements for reasonable wear resistance and easy repairability. Obviously the shellac would be glossy initially but that can easily be matted down as much as you like.
To keep the ash as pale as possible I'd have gone with the soap finish. It gives a dead-matt surface (and keeps it that way) and is surprisingly durable on a hard timber. I was sceptical of this I must say when I first read about it but tried it out on a busy working surface in my previous kitchen and it did well enough there over a 2-3 years span that I'm quite happy to use it in less challenging applications.
