PAC1":2qk1iv4u said:It is the wrong approach the dust has to go past your nose to get to the filter. Far better to capture as much as possible at source then you do not breath it and the air cleaner is plenty big enough.
woodpig":3janpsoa said:I use the Record power AC400 for my 5m x 3m workspace and it seems to work quite well. I leave it running on timer for an hour after I stop working.
woodpig":1ttaw7aq said:I can't tell you what the noise level measures but I'm sure it's on the record site somewhere. What I can say is it's not very noisy at all IMO. It's only a few feet from me when I'm turning and it's normally on when I'm sanding.
sunnybob":3iq8u42w said:I'm with pac1, I'm not keen on the fact this kind of filter draws the very fine dust upwards past your face. All filtration is good of course, but if I had one of those I would position it so it draws air away from where youre standing.
as far as noise levels, any smart phone can download a decibel meter app in seconds, so you no longer have the "in my opinion" debate.
My AC400 is mounted above my head near the roof. It actually blows filtered air past my face when I'm turning.sunnybob":2hez7xtd said:I'm not keen on the fact this kind of filter draws the very fine dust upwards past your face. All filtration is good of course, but if I had one of those I would position it so it draws air away from where youre standing.
woodpig":4554x53u said:Review here shows the amount of noise it makes.
https://youtu.be/E2qE9A3ijzs
sunnybob":29kxn3i7 said:I have a roller door at each end, so i can open it up after a big day and the wind blows the remaining fine dust out for me... If the filter can be placed so you are on the outlet side, thats much better.
skipdiver":3aglvnwz said:...I have the air filter near the door, at the opposite end of the workshop to where i do most of my work. I think it has definitely made an improvement to the working enviroment.
Moonsafari69":1kmjngjx said:. I know it's working 'ok' as the filter regularly needs a clean out...
