Could someone kindly help as to what connections I need to connect my propane torch to my propane bottle?Ihave sent a few images of connections on my gas bottle and on the the torch ,all help appreciated,
I’m not naive ,I know you need a regulator,I don’t know what BAR size or thread attachmentHoly cow man, if you don’t know you need a regulator in there, you just avoided something spectacular!
aidan
Thanks Kindly for your helpI seen to recall the bottle threads are two different sizes, iirc only 1mm apart, so stick the bottle in the car when you go looking to buy a regulator.
Thanks Kindly,Would 2 Bar be sufficient,I’m a learner regarding gas connectionsYou need a regulator to connect the torch to the bottle
https://gasproducts.co.uk/blow-torch-0-5-2-bar-propane-gas-regulator-with-gauge-3-8in-lh.html
While I quite agree that a regulator is is a good idea, you don't actually need one. You aren't guaranteed an monumental if you don't use one, but in the unlikely event of a problem, the regulator is supposed to stop any flame getting back to the bottle, and it does stop all the gas leaving the bottle all in one go, should you have a leak.. I have a big cast - iron burner that doesn't have a regulator, and while I only use it outside, and I don't use it very often, I am still alive. So far.Holy cow man, if you don’t know you need a regulator in there, you just avoided something spectacular!
aidan
Have you any instructions with your torch with regard to working pressure? There are a lot of different torches out there & you’ve only shown the hose connection.Thanks Kindly,Would 2 Bar be sufficient,I’m a learner regarding gas connections
Hi,Could someone kindly help as to what connections I need to connect my propane torch to my propane bottle?Ihave sent a few images of connections on my gas bottle and on the the torch ,all help appreciated,View attachment 98273
Thanks Kindly for your advise,Would you have a image or a link of a blowback valve?Hi,
Go to an engineering supply company that supplies gas bottles and they will put you right. The small connection is 3/8” left hand thread. The larger one is a standard bottle connection for propane. The gauge does NOT stop flames getting back to the bottle , you need a blowback valve in the hose as it comes off the torch as a minimum.
Greatly AppreciatedI think what Dave is referring to is a flash back arrestor, these are used when gases are used in conjunction with oxygen such as oxygen & acetylene used for cutting & welding etc. If you intend to use your propane in conjunction with oxygen then it would be wise to fit flash back arrestors, I use oxy-propane for lead burning so have FBA fitted on the hoses.
If you are just using propane on its own there is no requirement for a FBA, if there were camping stoves etc that come with a pre-fiffed hose & regulator would have a flash back arrestor also fitted.
