DangerousDave
Was ripping some MDF today, the cutting list called for 4 lengths each 254mm wide. So I measure from a good edge and make a mark at 254mm, 508mm, 762mm... congratulating myself on the good practice of taking a running measurement...You can see where this is going...I set the guide rail to the mark and made each rip cut. Decide to double check the width and was baffled at how I had lost a couple of mil in the width...It took a while for the penny to drop ...The Festool might be good, but I don't think they've invented one with a zero kerf blade yet I have no idea what I was thinking... :roll:
Things then went even more Pete Tong. Made the crosscuts on my (now too narrow) lengths and was equally as baffled as to why they weren't square (I double checked the crosscuts with my combination square). So I measured the sides with a tape measure; both pairs of sides were parallel their entire length. Had I inadvertently hit the 'create rhombus' button on my new Festool :shock: I was now resigning myself to the horrendous task of nibbling away a wee bit from the sides on the TS to make them 'square'. Then, once again, the penny slowly dropped Out came my trusty Stanley 6" square and right 'nuff the pieces were perfectly square. The feckin combination square wasn't tho :roll: Glad I found that out now though, I use that combination for everything and trust it implicitly. There's a lesson to be learnt there all right...
Needless to say the language was choice :evil: But I've calmed down now...
