Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Normal
Klingspor, because I like the name.They are all much the same as far as I know.N.B. paper-backed used wet (with white spirit etc) is brilliant for plane soles and similar. Splash it on your flat surface and the paper sticks tight (enough) and dead flat, once the paper is soaked through. Keep it wet while you flatten your sole. 80 grit will do it.
