Chrispy
Just filled out an order for router bits and thought lets have a look at the clearance section and there is a set of four bits in a box that contains one of the cutters I have on my order and the whole lot was £3 cheaper than the one cutter alone, How does that work then? same quality same cutter.
check it out if you like, Wealden's it was.
