Wax on top of Danish Oil
motownmartin
10 May 2007
Enderby, Leicester
I fear that I have made an error, I have made some Walnut Boxes finished with a coat of Danish Oil the some Chestnut wax (.22 I think) but the wax is tacky and when I touch it my fingerprints are left on the surface, Have I made a mistake by waxing over the oil, if so how can i rectify it :?
Wax over an oiled finish should be OK once the oil finish has gone off. Bear in mind however that a Danish oil is made from a resin, a polymerising oil (like Tung or linseed) and a solvent. It's really a long oil varnish. Waxes (eg like Black Bison and similar) are generally formulated with a solvent which makes them easy to apply so there is a danger that the solvent in the wax could soften the varnish (ie the Danish oil) but I have applied wax to a Danish oil finish (usually, Liberon finishing oil) lots of times without problems.
I am unfamiliar with the Chestnut wax but I would have thought that if you leave it a week and polish the heck out of it, it should be OK.
Martin,
What did you use to buff the wax with? I now have one of these Chestnut brushes:
It does look like the bristles are too course but it works a treat.
You need to brush quite hard to get the wax to flow before it hardens off, sounds like you need to apply more elbow grease. :wink:
DaveL":2gchjjsj said:
Martin,
If you haven't got the elbow grease like me use the Drill Polishing Brush
http://www.chestnutproducts.co.uk/results.php?cat=Polishing Brushes
Much easier :)
