Bodrighy
Is there a cheap source of wax for sealing blanks etc. I can't seem to get candles cheaply round here and wondered if there was any other way short of eating 2 ton of Edam.
sawdust maker":99og7lpj said:.... But a word of caution in heating it if its like candle wax its easy to set light to. Not sure I like the idea of heating is in a meat dish. .....Paul
Paul.J":19ongsbs said:We used to use a liquid wax to stop pieces been glued together when i was an apprentice.Don't know who made it.
It was in an old gallon tin.It was used cold straight from the tin.
No doubt it would be too expensive.
Think you will find the wax just as messy though.
Paul.J.
Anyone here tried old emulsion ?duncanh":38nw48g8 said:I don't know how it compares price wise, but I use the cheapest PVA glue that I can find. It appears to work. I've also seen left over emulsion paint recommended but have never tried it.
Duncan
I use maybe 20% of water, just enough that it can be spread with a paint brush.Bodrighy":2gcotonr said:I have been using PVA but it has become a pain when I have a load to do as it takes so long top dry out and hets everywhere. I was using it diluted 50/50 with water.
CHJ":3msfdfvn said:My main sealer is Hot Wax, when sealing green end grain and nearly dry Blank Rounds edges.
If possible I let the green ends sit in the hot wax a few seconds to watch the water boil/steam out and this seems to draw the wax in as it cools and bonds better. I keep my eyes open for sell-off of surplus Xmas stuff etc. in the likes of IKEA. and market stalls.
Emulsion, old paint, oil or water based works fine and is easier for large branches that are awaiting storage space.
In fact I think it's the best use I've found for the last lot of water based rubbish we purchased.
You can always offer to clean out all those old half full paint tins in your friends and family sheds.
Yes and as quickly as possible after cutting, preferably minutes.Hutzul":1ejf4d7k said:...So am I right in thinking:-
If wood is green: seal the end grain
No, rarely is it necessary or desirable to seal side grain. *Hutzul":1ejf4d7k said:...If wood is nearly dry ( I guess less than 20% moisture) then seal side grain.
Hutzul":1ejf4d7k said:...Is there a golden rule to determine whether to seal end grain or side grain ?
CHJ":1uauu62i said:Yes and as quickly as possible after cutting, preferably minutes.Hutzul":1uauu62i said:...So am I right in thinking:-
No, rarely is it necessary or desirable to seal side grain. *Hutzul":1uauu62i said:...If wood is nearly dry ( I guess less than 20% moisture) then seal side grain.
Hutzul":1uauu62i said:...Is there a golden rule to determine whether to seal end grain or side grain ?
On normal split or cut logs do not seal side grain, only the ends.
Only reason for sealing all round a cut circular blank is that it is essential to get all the end grain and the small amount of side grain on the edges that gets covered is of little consequence against the risk of not getting the side grain.
Do not wax the side grain on the faces of the cut round blank.
* The only time a cut blank is covered completely is in the case of green woods such as Olive and Eucalyptus burrs etc. which carry a lot of moisture and need to be forcefully restricted from loosing it too quickly.
Have a good look around a turning blank sales rack and the 'norm' for safe drying and storing will be obvious.
