Cutting Crew
Hello All,
Anyone had any improvement with spraying water based lacquers recently?
The last time I tried some for a review, although I found it easy to get a good finish I couldn't help breaking through coats, leaving the fine white markings of the sanding as it got between the coats.
I read an article when I was last in the US that mentioned the critical timing between applying coats could eliminate the problem.
Regards....Mike
Regards....Mike
