The following are from the United States Department of Agriculture Forest Service Forest Products Laboratory.
http://www.fpl.fs.fed.us/documnts/fplrp/fplrp462.pdf
http://www.fpl.fs.fed.us/documnts/techl ... midity.pdf
http://www.woodworks.org/wp-content/upl ... eriors.pdf
From p 22 of the third link:
I've picked out a few:
Linseed oil gets zero as a water vapour barrier!
Moisture-excluding effectiveness of three coats of various finishes
(ponderosa pine sapwood was initially conditioned to 80°F (25 degrees C?) and 30 percent relative
humidity and then exposed to 80 °F and 90 percent relative humidity for 14 days)
One-hundred percent = perfect protection or no absorption of water vapor; 0 = no protection as with unfinished wood
Paraffin wax-dipped - 95%
Epoxy finish—clear (2-component) - 91%
Polyurethane paint–gloss(2-component) - 74%
Paraffin wax–brushed - 69%
Polyurethane finish–clear(2-component) - 66%
Enamel paint–gloss (soya alkyd; interior) - 59%
Shellac - 42%
Oil-based house paint - 41%
Spar varnish (soya alkyd) - 30%
Nitrocellulose lacquer - 10%
Tung oil - 2%
Linseed oil - 0%
furniture wax - 0%
Unfinished wood - 0%
