Water for wild birds
Eric The Viking
19 Jan 2010
Following on from the earlier thread, I was wondering:
I've been putting out a small plastic tray of water (from food packaging), fixed to a slab of floorboard so the ground beneath doesn't freeze it. But that didn't work yesterday afternoon: it froze twice in 90 mins or so, even though I start with warm water.
I can't keep checking it all the time so I wondered if heating some pebbles either in the oven or near the fire might help, or perhaps adding a bit of sugar, to lower the freezing point. I don't know if the latter would even work (I'm assuming sugar has the same effect as salt - obviously can't add that!).
Anybody tried either or has someone got a better idea?
TIA,
E.
PS: I know the arguments about hot water freeing faster - not that hot!
Sit it on top of a hot water bottle wrapped in a towel, that should keep it warm for a few hours at least.
Use a polystyrene tray to help insulate it?
Thanks. The floorboard is for insulation and doubles as an anchor. I'll keep an eye out for a plolystyrene tray (awkwardlyhad the recycling taken only this morning).
I know making it deeper would help, but that also makes it less safe for the smaller birds and harder to fix down so it can't be tipped over.
Ping pong balls! if its in a breezy spot. The constant movement of the floating balls should slow the freeze a little.
Or maybe a smaller version of one of these? A float with holes in.
    15.8 KB
