goldeneyedmonkey
Right here's the thing...
I'm pretty sure, although I now can't find it, that I've seen a mitre jointing router bit. Its a cutter that joins the mitred edge together in a similar way to a T&G groove.
So that on the edges where the mitre meets there is a joint more or less the same as a Tongue & Groove, so will provide the look of simple mitred edge, but has good strength from the joint, instead of just relying on the glue.
I suppose I could just use a T&G set/cutter, with a mitre fence. But the one I'm thinking of does the 45 degree for the mitre as well. Or was I in fact just dreaming!? If anyone can help it would be much appreciated.
Thanks in advance_Dan
