glenfield2
I bought a couple of iroko wood block worktops a few weeks ago, trimmed them to size, sealed all round with several coats of Danish oil then left them on the kitchen units unsecured over maybe two weeks around Christmas. Just gone back to the job and both are bowing significantly across the widths which will clearly be an issue when fitting sink and hob.
They are on a boat I’m refitting (on dry land) so pretty cold inside but weather tight.
Anything I can do to rectify matters? Would it be worth trying to gradually pull them flat?
The amount of bow varies but at worst if the rear is flat down the front edge is lifted maybe 6-7mm.
