Bigroomboy
Hi everybody! Long timer lurker here but just joined up to post.
I have gained a lot of help from this forum reading old posts, so I thought I would try to pay something back. I'm part way through restoring a Wadkin 10 AGS as my first proper table saw. Anyway after doing quite a bit of searching I didn't find much info on replacement spindle bearings for the older spec 10 AGS.
The manual says g 88503 (skf). After eventually getting the old ones off the shaft the were labeled 6203ff, on the side not visible!. They had measurements I expect were the same as the originals. ID 17mm OD 40mm, outer flange 12mm inner flange 16.6mm. odd having a wider inner race but I thought I would have no problems finding replacements. Not true! There were some in the US and some advertised in Europe but on enquiring they wanted 50 euros each! I didn't order from a place 123bearings which turn out to be in France, not cheap for the 2 at £40 but they claimed they were premium. On arrival the measurements were not as advertised with the inner race being 20mm. I wasn't very happy about that after paying so much but I did eventually get a refund. On further investigation people seem to treat these older bearing designation very loosely.
Finally to the point, I did what I was tempted to do at the start. I bought 2 skf 6203 2rs very popular bearings and 2 for less than £10. Then I bought 1mm and 0.3mm shim washers (17mm ID) to make up the missing 2.3mm on the top and bottom of the spindle. I used a couple of small drops of super glue to keep them in place. So far it seems to have worked perfectly and makes for a very easy replacement.
One final point is the fine adjustment on the old fence. I cut off the damaged section of the gear at the end. On the lathe I then removed a similar amount of the cast handle. This may weaken the whole thing but so far so good!
