Just finished a small table. The top is made from elm and three glued up boards using PVA glue.
Although the panels looked fairly matched when I dry fitted them together, on glue up and after sanding staining and top coat, I find that the glue line is very visible, well it is to me and doesn't look like a single board.
I'm sure someone will have had the same experience. I was considering re sanding then maybe darkening a little more with stain down both sides of the glue line????
Any comments would be appreciated.
