I was wondering if one could use a 1mm thick plane blade with a very thick chip breaker that could work without chatter. Reason I ask is simple, a thin blade is way is easier to maintain; no need for grinding.
Stanley plane blades are around 2.2 mm or so. The stanley chip breaker is not so sturdy, yet when tuned correctly it works ok. I was thinking about the possibility of using a very thin blade with a very thick 2 piece chip breaker. One that extends closer to the cutting edge than the clifton cap iron.
Thanks.
Thanks.
