Price £20.00
Collection preferred please or I can post for extra £4.00 Post Office 48 hour tracked
Never used - package just opened for photos.
There are two main problems with a typical marking gauge: you have to tilt it just right to avoid pin chatter and, even then, the pin tends to follow the wood grain, throwing off your line. The Veritas wheel marking gauges solve both problems. The hardened steel wheel cutter scribes perfectly at any point of its circumference. Since it cuts wood fibres rather than tears, it marks cleanly, even on cross grain. The wheel's single-sided bevel also pulls the gauge face against the stock, maintaining accuracy. Its cutting edge is at the extreme end of the rod, useful for transferring dimensions such as tenon shoulder and mortise depth. The wheel retracts into the face of the gauge for storage and protection. The gauges are very easy to set, since each has an internal O-ring to keep light but constant friction on the rod.
Key Features
Hardened steel wheel cutter
Cuts wood fibres, rather than tears
Marks cleanly, even on cross grain
Use as a depth gauge to transfer measurements
