Ian Dalziel
What a fantastic little gadget this has turned out to be. My scrapers have been gathering dust of late and i decided to give them a treat. i have used old saw blade steel for my scrapers and the filing and honing has taken its toll. they are normally filed then honed on the stone then given a rub off the edge of and old round turning tool to get the burr, crude but it always gave reasonable results.
I saw this advertised and thought what the heck i'll give it a go..... it comes with a scraper with the edges already burred but i cleaned these off so as to set it to my liking. it even has instructions for use on the reverse of the box.
The variable burnisher has a carbide rod fixed at an angle inside a brass hub, the hub can then be set from 0 - 15 degrees. i was never sure what angle i was putting into my scrapers but found the angle set to be helpful in that i liked the 10 degree setting. The body of the burnisher is shaped to suit my hand and has a slot running the entire length to allow the scraper to be pulled along the carbide to create a burr. No more careless misses and cut fingers for me.
It works great on old and new scrapers. I also liked the scraper that came with it.
testing my scrapers i pushed and pulled over some twisted grain ash and they cut excellent almost effortless. feather like shavings from whatever angle i used.
I like to feel the scrapers just using my hands but the heat sometimes generated i might consider buying one of their holders.
I must admit that i'm starting to blow the dust off the hand tools more and more.
Would i recommend it........Definitly.......... for seasoned scraper users or new to burnishing process give it a try.........first rate little gadget
regards
Ian
regards
Ian
