However, with some other chisels, particularly older, bevel edged ones, wide and narrow, I had some swivelling problems. I think it’s to do with them being not ground perfectly flat on their faces (the bevelled side) - whether from manufacture or wear with age I don’t know. I fiddled about a bit with them, and found they were held much, much better if they were placed off-centre in the blade clamp. My suspicion is the surface of the clamping bar may make the difference. In the centre the surface is level right from front to back, whereas on either side only the front and back “rim” bears on the blade, which seems to give better grip. I don’t know, but it does seem to work better off-centre; my only minor concern being how much that might effect the clamping set up over time.
