i have one of these, and find it useful, especially for shortening dowels.
there are two advantages of the veritas one, when not in use, the blade can be hidden safely which means it does not need sharpening so often.
second point is how do you make a handle like the veritas one which is so low, and holds the blade well, and straight and level.
i can see that it seems expensive when you have lots of old plane blades,
BUT how often do you actually make these devices to save you time and money.
it is also useful for trimming veneer edges, although i start out with my veritex edging cutter which i find very useful
paul :wink:
