Veritas Carver's Knife
sihollies
24 Feb 2013
Lancashire
Hi
I have just completed my first marquetry project, of which I have thoroughly enjoyed.
I own a few Swann Morton Scalpel handle which I use for my Parquetry work, but found the handles a bit awkward
to control when making tight curves on the a fore mentioned marquetry project.
I found it easier to navigate the the tight curves with a cheap craft knife handle, that I own, where the handle as more substantial/bulkier.
I stumbled across this Veritas knife, and was wondering if anyone could tell me if Swann Morton blades can be used with this handle? ( The blades in the picture look identical to Swann Morton ones )
http://www.thewoodveneerhub.co.uk/verit ... r-s-knife/
I am aware it is a Carver's Knife, so I am thinking the blades may be thicker??
Any advice is greatly appreciated
Regards
Simon
Thanks very much for the rapid reply.
I searched the Internet for ages and found nothing and you came back with an answer in 20 minutes, so thanks again.
I just have to decide now if I the knife is worth it for the cost, as opposed to my cheap craft knife handles.
But with Christmas looming, it may be a possibility.
Many thanks
Simon
sihollies":2cv93acq said:
Hi
I've seen craftsman (at shows) with scalpels where the handle was padded and customised with
polymer clay.
BugBear
It seems to cost quite a bit for what is really a handle. Maybe you could bulk up the scalpel handle by sticking some wooden scales on each side. Another idea I've seen is to wrap it with a sort of mouldable plastic that sets hard,
Scalpel handles are not ideal if you need to press quite hard when cutting. I found that out when try to cut into maple for an inlay.
Thanks Bugbear & JohnPW
That's a good idea. I tried wrapping the handles with tape, but couldn't get the right 'feel'.
I think I have some 'Fymo' somewhere, so will certainly give it a go.
Will post my findings.
Simon
I will definitely try the Ernie Ives handle, as it is designed for the marquetarian & the cost is small, compared to the Veritas handle.
However I will also try the Polymer clay suggestion too, as I should be able to mould it precisely to the ergonomics of my grip.
I truly appreciate your suggestions, so thank you
Regards
Simon
Swann Moreton do this more chunkier holder:
Rod
I have a Swann Morton scalpel. To make the handle comfortable I wrap it with sports tape - the kind they use on the handles of tennis racquets etc. Got it off Ebay.
Thanks again everyone
polymorph looks interesting, so I may give that a go.
£4.30 + £1.60 P+P for 250 grams on Ebay.
The handle from John Lewis looks good too, but it costs nearly £25
Thanks again
Pete Maddex":29svq10a said:
I got a nice scalpel blade handle from John Lewis, round body very nice to use, can't find it on the web site the closet one is this http://www.johnlewis.com/prym-art-knife ... s/p1297174 mine has a metal body not plastic.
That's ridiculous, £20 for what looks like a plastic handle with a metal collar! But that's the other common type of knife used for fine work, I believe the original brand is X-Acto:
http://xacto.com/products/cutting-solutions/knives.aspx
but there other manufacturers making them. I got set from Lidl for £4, had 2 all aluminium handles and 8 blades. The blades have a hole in them but don't appear to have any function. I've also seen a version with a plastic collar that grips the blade, which I guess would only be suitable for very light use.
bugbear":29svq10a said:
Cheshirechappie":29svq10a said:
Ernie Ives designed a knife taking scalpel blades specifically for marquetry work. Might be worth a try, especially as it's not particularly expensive. Here's one source - http://www.amazon.co.uk/s/ref=nb_sb_nos ... ry%20knife
Interesting - and cheap. TERRIBLE photo on Amazon though!
BugBear
And very little product information, is it plastic, metal, wood? How is the blade held? For that price it could be just an plastic handle with a hole at one end and the blade just slots in.
    237.5 KB
John, I didn't check the price wow! I only paid £5 or so for mine.
Mine is more like the X-Acto one
JohnPW":1nz6vrpr said:
BugBear
It is plastic. The blade fits into a slot and there is a collet that slides over it. You then cut and the first time it moves and must locate itself against the collet. The big advantage over anything I have seen is that you can have the blade protruding a few mm, rather than 20mm or so unsupported. It is good value for money, but isn't high quality. It is good enough quality for the job though. If it was double the price I would send you mine and say try it but by the time we have posted it there and back it isn't worth doing.
