pip1954
hi i have made some tables for her in doors and veneered the tops with walnut with pva type glue and sprayed with morels laquar after a couple of weeks the veneer is starting to lift in lines across the tops (along the grain) it looks like cracks the tops are mdf two skins of 12mm glued together
question what have i done wrong
veneered some other bits and they where fine glued and finished the same way with same glue
could the glue be of
would i be better of using casamite
pip
pip
