I got myself a Dewalt 626 recently and used it for the first time today, hooked up to the power take off point on my Fein extractor.
2nd cut - the fuse blew in the plug on the Fein cable. It seems that the startup of the router together with the startup of the extractor was too much for a 13a fuse. The only way to get it to work (after replacing the fuse) was to start the router up, then switch on the extractor. Which kind of defeats the point of the power take off.
The Fein has a power take off rating of 2000w (the DW is 2300w :roll: ). I see that the Festool extractors are rated at 2400w. Is the only solution to upgrade the vac to a Festool? Or can anything else be done so that the DW can be used with the Fein (not to include replacing the fuse with a bolt (homer) )?
Karl
Karl
