bertterbo
I'm thinking of purchasing a vacuum chuck setup. I currently don't have a compressor and have no real need for one, so instead of going the Venturi route, I plan on just getting a vacuum pump as they're much smaller and less noisy. I also have plans to do some wood stabilisation at some point, so that would be another use for a vacuum pump.
My planned parts are :
https://www.turners-retreat.co.uk/vacuum-adapter-kit/p156https://www.turners-retreat.co.uk/vacuum-hose/p395https://www.turners-retreat.co.uk/vacuum-head/p385
And then for the pump, which from my research, needs to be at least 3 CFM, I thought I would go with :
https://vacuumchambers.eu/en_US/p/Vacuum-pump-VP160,-170lmin-6CFM/24
Is this all going to be compatible? will I need anything else? I'm not sure what connections may also be needed?
