JSW":gy4qikbz said:
I'll take a load of abuse for this but so what.
Every table saw, circular saw, track saw or whatever saw I've ever owned I've removed the riving knife from almost immediately, it's a redundant archaic item that simply inhibits the use of the saw, IMO.
If a work piece ever binds, I back off the cut, try again, or part the cut with a wedge, chisel, or whatever's to hand.
All digits fingers toes and body in one piece still, and been that way for 40 years as a pro Joiner.
Bring it on.
I think you fundamentally misunderstand the purpose of safety features in this instance...
The gist of your argument is that you can remove it, and then remain safe by virtue of vigilance and skill as an operator, that's probably true given you still have all your digits. However the point of the feature is to protect you in the instance that you don't spot the danger in time to prevent a kickback, it's intended to supplement your ability as an operator, not substitute for it.
If the riving knife is getting in the way of how you use a TS, that's usually a sign that a router, spindle moulder, or crosscut saw is actually a better tool for the job.
The only thing we agree on is that riving knives are archaic... Totally enclosed, power fed saws are clearly safer, and more efficient, and using a tool where ones hands may pass close to a fast moving cutter is so 1900's! (Not really practical to always use though, bit like relying solely on skill to protect yourself really).
As an important side note, under the H&S Regs you'd risk both civil liability and criminal negligence charges if were to have an employee, collegues or friend who use or borrowe one of your "adjusted" tools suffer a mishap, as the regulators would see it as you intentionally removing a safety feature fitted by the manufacturer. You can argue all you want on here, but it wouldn't fly with the HSE or the courts.
Edit: In fact even before it gets that far, a client safety rep or auditor wouldn't accept any 'justifications'... Were you to come to any of the site's I'm based at with those tools, there's a good chance you'd be kicked off when your tools were inspected on entering and as a result you or employer would be removed from the approved contractor list, permanently.
