Up to £146 OFF MarMan Tools Pivoting Router Lift Packages
Wood Workers Workshop
UKW Sponsor
16 Nov 2021
Threshing Barn, Upton-upon-Severn, Worcs WR8 0SN
Up to £146 OFF for a limited period
Get up to £146 OFF our MarMan Tools Pivoting Router Lift Packages. A premium metric router lift allows a spindle motor to pivot at any angle between -5 to +50 degrees with AMB-Elektrik 1400 FME-P Milling Motor.
FREE UK Delivery on all orders over £75
We ship worldwide, duty and tax included - click here to find out more
MarMan Tools Pivoting Pouter Lift RL3.0K
A premium metric router lift that allows a compatible spindle router motor to pivot at any angle between -5 to +50 degrees including 'snap to' points at 22.5°, 30°, 45° and 90°, giving countless routing possibilities including grooves, rebates, chamfers, mitre cuts with only one slot router cutter.
Adjust cutter height from above the table​
The T-Bar hexagonal key adjusts and locks the height from above the table with 4mm per rotation.​
Powerful Motor
Our packages come with a powerful AMB-Elektrik 1400 FME-P Milling Motor and ER20 Collets.​
Made in Germany
The red anodised, solid aluminium and precision ground top plate is very strong and flat.​
Easy to use
Smooth-running spindle columns allow continuous and exact fine height adjustment.​
