Hi I've just joined this forum hoping to improve my skills in turning after being given an old Lathe to play with while I recover from a pretty serious Brain Operation.
The Lathe has no name on it but it must be from the 50's or 60's at least pre 77 as the motor has the old wiring system colours. The motor is a large Hoover motor made in Cambuslang Scotland but that is the only plate with writing on it anywhere. It has a 12 " swing (UK) i.e. 6 " centre to bed and about 3 ' max length to tailstock. It came with no tools nor chuck or faceplate. I have done a little turning on it but now wish to proceed to making a few bowls and end caps for things. I also fancied a tailstock chuck so I could drill holes from that side. Because I have no idea what the lathe is I have had trouble finding the right faceplate and chuck plus I definitely do not want to be spending a lot of money on a jaw lathe chuck without knowing it will fit. I did bite the bullet more in hope than expectation and made a best guess after measuring the width of the screw fitting on the headstock & got a 4" cheap record faceplate of 1" screw diameter 8tpi thread but this screws on to the first few threads then sticks. I obviously didn't want to force it any further so I assume its the wrong size. I also paid a few quid for a 2 MT tailstock chuck but it was too big so this has taught me the bore is either 1 MT or 0 MT.
Anyway I have pictures of the lathe & wonder if anyone could identify it or give me some clues as to how to make sure I buy the correct additions so I can try new things with the Lathe. Thanks in advance to anyone who can help
