StilwellDesigns
I just bought an old Union Jubilee lathe, and was hoping someone out there has some knowledge of these old machines.
Firstly, what is the best way to change speeds? Right now I'm having to loosen the two bolts holding the motor down, lifting it up and locking it off, then changing the belt on the pulleys, then lowering the motor again.
Is that the correct way to do it?
Second, what is the correct tension for the belt?
It seems to be overloading and tripping if it's too tight, but then if it's too loose the work keeps stopping, I can't seem to find the sheer spot.
Any hints or tips would be much appreciated!
