pgrbff
The collet nut unscrews fully but the bit remains stuck fast. Any ideas on how to remove?
Also to prevent bottoming the cutter, put a rubber O ring in the collet and let the bit bottom on that and then lift slightly before tightening the collet.At the risk of stating the obvious, the Festool routers, and others as well, have two loosening points for the collet. If you turned the nut until it was loose, keep turning it and it will loosen again to free the cutter. This won't work if you bottomed out the cutter in the collet.
Could the stain be resin from the timber you last worked? That may have caused tackiness.The collet was correctly inserted in the nut, infact the nut unscrews completely but is still attached to the collet.
The cutter wasn't bottomed out either
In the end, I placed the spanner behind the nut and tapped it out with a hammer, it came out with the collet still attached but bit now loose.
Still not sure why it jammed, it is a relatively new bit and apart from a bit of staining on the shaft it appears nice and smooth.
