Robbo3
Two Questions - Drilling Hss & Lathe Lubrication.
How can I drill rivet holes in an industrial hacksaw blade which is presumably either hardened or high speed steel?
Some years back I made a narrow parting tool from a piece of blade from a recipricating hacksaw. After grinding a tang I made a conventional round handle to suit.
Having offered to make another one with flat sided handles for a friend, I realised that I only have HSS drill bits & they won't touch it. Hence my question.
Lubrication Points
My lathe, a Draper WTL-90, the type with split pulleys, has lubrication points that are spring loaded ball bearings, inset so as to be flush with the end of the shafts. Working on the principle that any lubrication is better than none, I have always used an oilcan with a nozzle & a heavyish oil. The problem with this is that if I overdo it, oil gets thrown everywhere.
Another friend has suggested that I should be using grease instead of oil but could offer no solution as to how to get the grease into the shaft. My knowledge of grease guns is limited to, that they have a nozzle which pushes over & clips onto a grease nipple, which obviously it can't do in this case.
I have seen cone nozzles which screw on, I presume, in place of the standard nozzle. Is this what is required to grease this type of lathe?
The manual for the lathe makes no mention of there even being lubrication points, let alone how to go about it,
- http://www.drapertoolbox.co.uk/link/1/63938ins.pdf
So if grease is the correct lubricant, what type should it be & what equipment is needed to apply it?
Regards
Robbo
Lubrication Points
Regards
Robbo
