Turning old Elm?
PJBG
New member
3 Oct 2023
Wotton under Edge. Glos
I removed a purlin form a cottage, guessing that the purlin is about 150 years old.
I had ideas about turning it on a lathe at the local mens shed.
Can anyone advise if wood of this age can be turned and if it is sensible to do so.
As per pictures.
Thank you
Jack
Yes. You'll need face protection & a respirator.
Start with a slow speed until all the loose stuff has gone.
The forum has a wood turning & lathe section which probably would be a better place to ask.
Like Robbo I would say yes as well but would first saw out a blank of the harder wood to reduce the amount of nasty dust flying around.
John
hope u know how to sharpen a bevel coz u gonna be needing that skill......
I cut up a 200 year old Oak beam at my house......it was as hard as concrete......
the chains on the saw would go blunt with mins.....
As per pictures.
Thank you
Jack
Looks like it's full of worm to me, but you should be able to turn it as elm doesn't get hard like oak does. I planed some old elm boards and it was lovely wood to work with.
I'd give it a go as long as you're sensible with lathe speed and get it into a chuck asap you could get some nice bud vases out of it
