big chief":36jymprb said:I was looking at the Supernova chuck. Sorry if these are silly questions, but are the jaws that come with it the ones to use for goblets, or would I be better off with a different set of jaws? I see there are LOADS of different jaw sets.
not silly questions at all big chief, the standard jaws that come with the supanova are fine to use, you'll need to get an insert for the chuck that matches the thread on your lathe, about £20
Why can't things be kept simple?!?!? There is far too big a choice and just too confusing....... :? :?
Just ask if you are unsure about anything, we've all been there mate :wink:
Thanks Dean. Have noticed everyone on here seems very keen to help.
Its greatly appreciated!
PowerTool":pj7jcm0k said:Or have a look here - click on the goblet (or "wine glass") to see the video to go with it;should give you some ideas.
Andrew
PowerTool":1swfuwf7 said:Hi there,Big Chief - I have a Clubman K10 chuck,and normally for goblets,use the H-type jaws;however,until I bought these jaws,I made several just using the C-type jaws that come with the chuck as standard.
Mount timber between centres,turn to a cylinder,reduce one end to a spigot the right size for the jaws,then mount in the chuck.
As with nearly all things with woodturning,this is one method for doing it - you have to work with what you have available,and there are several ways of achieving the same thing.
Above all,be safe,and enjoy it
Andrew
