JesseM
I obtained a Sargent 1080 combo plane and just recently got around to trying it out in anticipation of cutting some 1/2 dados. I sharpened the 1/2 cutter, and the nickers. I used a DMT knife jig for sharpening the nickers which worked really well. My first attempt at using this did not go well. it seemed like the nickers preventing the blade from engaging. Looking for other things that might be wrong I noticed the skates were hollow around the mouth? (if you can call it that). I also noticed that when I had some depth that the skates were binding against the wall of the dado.
So I am just wondering if there is any advice for tuning this plane up. Are the skates supposed to be flat? The plane appears to rock front to back a bit. I had a hard time getting the blade to engage. I had read somewhere that the way to use these from end to start and start to end.
Thanks for any help!
