tulipwood prices?
shim20
30 Mar 2008
hadleigh,suffolk
dose anyne know the price of this per cubic ft/mt would be a great help, meant to phone the timber yard today but had no time in the end and need to work something out,
cheers
sorry forgot to say for 1" stock
Hi,
I bought some a few months ago from Brooks Bros.
http://www.brookstimber.co.uk/
I paid around £18.00 + VAT per cu. ft. for 1 inch (though I don't think it's much different for thicker boards). I have been quoted as much as £22.00 per cu.ft.
Incidentally, service was tremendous with delivery the next day. For a large company, I was impressed.
They probably won't deliver less than around 10 cu.ft. but they don't have a minimum purchase amount if you can collect.
Hope that helps
I recently had some 2 1/2" Tulip and was quoted £575 +VAT per cubic metre, which is almost half the price of steamed Beech!!
Timber suppliers don't often show prices on their websites because they vary so much from batch to batch!!
Hope this helps
Richard
We're selling tulipwood mini packs at the minute as well as loose boards, its a paint grade timber so its cheap as chips...
...I just logged into the office, and our 1" tulipwood is £400 per cubic metre plus the old VAT collected from the yard, obviously we can deliver if necessary although like most things the price depends on the volume, sometimes courier is the cheapest option.
The Mini packs are slightly cheaper and contain around 1.70 - 1.90 cubic metres.
Stig,
surely you should be a Stig, or another Stig rather than the Stig?
As for tulipwood.......I have never used it.....in fact, I wouldn't recognise it. You say it is paint-grade timber? Does this mean that you can't use it au naturale for furniture?
Mike
Tulipwood usually can look a bit like birch or maple but often has black and green streaking and small pin knots and is quite soft so is usually used for a paint finish
jon
Am using tulipwood for someplantation shutters at te=he moment (got it from SL Hardwoods) and I'm very happy with it. The colour does vary wildly though. Heart wood goes from lemon yellow through to green then olive green them aubergine as you go down the trunk. (or is it the outer wood? must check…)
I guess I'll be painting it too as the green bits look like tanalised wood. Wierd
I've used a fair bit of tulipwood over the years, mainly for the doors and face frames of kitchen cabinets. It's fairly cheap, machines nicely, and paints well.
I no longer really use it, however.
The main problem with tulipwood is that it can be very soft, and in high usage areas such as kitchens it will dent very easily, no matter how good a paint job has been applied.
For this reason I now use beech or sycamore for painted work if solid wood is required, but in most cases use MR MDF, which is a lot cheaper even than tulipwood, and if used correctly is a better material for the job.
I now only use tulipwood for mouldings and cornice, for which it is ideal.
I would expect to pay around £20 per cube for 1"
Dan
Another choice if you was painting the timber would be paint grade beech you get a touch timber for a paint grade price :D
