Hi all,
Do any if you metal guys have any tips for tube bending? Ive got a manual rotary draw bender ( 32mm dies ) which i bought about 15 years ago and haven't really used. I tried when i got it but the first pipe deformed badly so i bought cold drawn tube and it was a bit better but still deformed badly so i gave up!
I also bought a roller bender at the same time. It worked great on 1" galv tube!
More recently i had to bend some tube ( 2", the customer had some 2mm, it deformed badly as the bend went on and created a v on the inside of the tube despite going slow and steady next i got some 3mm and that was better, but still did the v by the time we got down to the required radius.... which was about a quater of a 1500mm diameter circle
So..... can you give me some hints or tips?
Thank you, kev
Thank you, kev
