I know spring is on it's way and temperatures are on the up, but this is ridiculous. A trip to the Honda garage is due methinks, unless someone can proffer a solution.
Problem solved - apparently it's a faulty sensor as it now reads 55 degrees C, which in itself is no great shakes, but it affects the heating system whereby I can only put the heater on boiling hot or freezing cold :evil:
A trip to the dealers needs to result in a good few hours labour as the front bumper needs to come off :shock: Luckily it's still under warranty, but still, for a 40 quid part, I bet it won't work out cheap. The joys of modern hi-tech motoring eh?
My last Honda only had a sidelight bulb go in 3 years of high mileage ownership. Bl**dy new fangled cars. :wink:
Mark - I had something similar happen on my previous car - a Mk 5 Golf. Outside air temp used to cycle down to about -80C and the climate control used to ramp up to compensate. Sorted under warranty.
