mickthetree
Pulling my hair out trying to get my head around this!!!
I need a couple of saw horses so thought I'd use the opportunity to get my head around some trigonometry. MISTAKE!!
I want the legs splayed at 15 degrees towards the ends and 15 degrees out to the sides.
I have read lots of articles but this is how I think it should be done. I'm struggling with thisthough!!
So I cut some test pieces. A leg cut at 15 degrees across the width and 15 degrees through the thickness:
View of it sat on the top
https://farm4.staticflickr.com/3902/14599875376_0d7c0fefc6.jpg
I tried cutting it into place on another test piece but its not 90 degrees to the sides.
If I draw around the leg as you can see it is a rhombus and not 90 degrees to the sides. Can anyone explain why this ends up like this? I need to understand so I can cut a housing into the side of the top or the leg.
