Trend T7e & Porter Cable 42160 Jig
smiffy151
New member
6 Jan 2024
Kent
Hi All
Please forgive my ignorance if not posted correctly as this is my first attempt... I have a Trend T7 router and have purchased a Porter cable 4216 dovetail jig. I have looked and the Trend T7 will not work out of the box and have seen a Unibase/180 adapter plate that seems to be the correct adapter for the router guides. The guides are two part with one piece through the bottom of the router plate and then a nut that holds the router guide in place.
The adapter from Trend Unibase 180 has two threaded holes on the bottom in the middle where the router bit comes through, however, the router guides from Porter cable are just attached as mentioned.
Has anyone had any experience with this sort of issue or setup, would be appreciative if anyone can offer any information
