Trend T10 problem
Baldhead
7 Jun 2012
In Limbo (Northumberland)
I mounted my T10 router upside down to use as on a table when the speed became very erratic, I remembered someone having the same problem some time ago, a quick search and I found out the fault was very similar to Eric the Vikings problems ie erratic speed, following Eric the Vikings instructions showed that the magnet had slid down the shaft and was not making the proper contact with the circuit board, pressing the magnet back down the shaft fixed the problem, so a very big thanks goes to Eric, secondly does anyone know if Trend have made any modifications to the magnets fixture onto the shaft, it's a very poor design considering the T11 is the same machine but has the facility to be adjusted from above when mounted in a table.
Baldhead
