Doug B
Shy Tot
You surprise me that you’ve had alignment issues with a 700 Roy I’ve heard of folks having problems with the 500 but not the 700, personally I prefer the 700 & have never had a issue with it.
offsets any error in the pencil marks
Firstly, the rail square itself has a relatively short length which means that the edge it registers from needs to be straight and free of bumps. This might require a "dust cut" to be done down one long edge with a long rail to get a known reference edge. For certain tasks this isn't always possible because you need the full 1220mm of width of board for the task, so you accept that might at times have a less than perfect edge to reference your rail square of which obviously has a potential impact on accuracyIf the rail square is at a fixed distance from the end and the angle is 90° then I cannot see why another parallel guide would be needed, any thoughts, comments or ideas?
Nearly all the alignment problems on any Domino are user-caused by plunging too fast. No snake oil solutions required, just some manual and guidance reading and some mechanical sympathy. I can make a row of tight dominos with no alignment issues, they are just a massive pain in the aris to assemble as they are so deliberately tight and de-compressing and expanding with the wet glue as you assemble.
Even worse if (as has been known in my case due to user screw-up) one needs to disassemble the joint, correct something (erm) and try again. The first time that happened was the last time I was OCD about having the whole row on the tight setting. I confess that was pretty early on (also pins).
Sums up well what I thought when I first saw a track square being demonstrated a few years ago.I NEVER trust the factory edge of any sheet of material that I work with.....The first cut i make, whether it be with a Tracksaw or a Router, would be to trim the long Factory edge so that I know it is clean and straight.
From there, you can square up the other 3 sides using whichever method you prefer and suits your needs/tools.
The Parallel Guides are especially useful when breaking down long sections of material, 2440mm lengths for example.
Trimming to length with the Rail Square afterwards is more accurate over the shorter distance but I wouldnt use it for a "Square" cut over 2440mm on any material that required high accuracy. ....Too much room for error IMHO!
I regularly work with & have to break down sheets of material that are 2800mm x 2070mm in size and the chances of laying a 3000mm rail & rail square on the narrow end of the board over that distance are prone to error, as J&K stated above.
The parallel guides do make a lot of sense, holding the track a set distance from one edge and cutting the opposite side parallel leaves just the ends to cut square to these longer sides. Now what you really want is a fixture that can bridge these two longer parallel sides from which you can then use the parallel guides to cut the ends.
Only problems are limited crosscut capacity, lack of portability - oh, and the price! Despite that I'd still like one when I set a home workshop up
Because with only 1 guide it is not a parallel guide.If the rail square is at a fixed distance from the end and the angle is 90° then I cannot see why another parallel guide would be needed, any thoughts, comments or ideas?
I’ve not seen any commercially available ones Jon which is why I use a ruler & ruler stop.Ok, I’m sold on the parallel guides, I’ve just looked on the internet and I can only see ones that fit Malupa / festool track, does anyone sell them to fit Mafell/Bosch track? Thanks
That’s a very nice MFT top but looks like you are cutting to pieces with the track saw. Can I suggest you route out a shallow slot about 3/4 inch wide along the long and short edges between the 1st and 2nd dog holes. Then if you make all your cuts with the track set against the same dog holes each time you won’t be making loads of cut marks in different places. If you are worried about tear out you could inset a sacrificial piece of timber into the 2 slots. If you are always trimming up a thin strip off the ends you could even sat the track of the edge slightly. You could save yourself some money by not having to buy a new MFT top so often.Fair point, but it depends entirely on the size of your MFT.....I had this one below made ( 1220mm x 2440mm and the cost was £100 and the holes are tighter and more accurate than Festools original MFT top) and I take it to every jobsite as long as there is room....Second picture shows it in use on a different job.
View attachment 108948View attachment 108949
