Aled Dafis
I've just been commisioned by Santa to make a couple of toy boxes for my two sons. Santa wanted their names on the front as well, I came up with this.
I made a couple of bookshelves for the boys earlier this year out of edge laminated Pine, which comes in 2440 x 650mm boards (8' x 2' ish) and found them to be easy to work with, and gave a nice finish with very little fannying around, so I decided to down the same route again.
Having dimensioned all parts, i proceeded to cut the tails on the Woodrat. Notice how I clamped all four boards together and cut them all at the same time. As these boards are quite heavy, I decided that a little support was needed. Do you think I could patent the "Adjustable, travelling work steady" (TM) :wink:
I then clamped the front/back panels in turn to the ends, in order to mark out the pin details.
I've actually cut most of the pins also, but was far too preoccupied to take photos, I'll take some tomorrow.
Aled
Aled
