AC induction motors, also known as asynchronous motors, use a rotating magnetic field to produce torque. Three-phase motors are widely used because they are reliable and economical. The rotating magnetic field is easily achieved in three-phase asynchronous motors because the phase angle offset between the individual phases is 120 degrees. However, single-phase AC motors require external circuitry which creates the phase angle offset in order to produce a rotating magnetic field. This circuitry can be realized using advanced power electronics, or more simply using a motor capacitor.
I'm selling it in favour of a 14" bandsaw and track saw.So I guess you should start looking for a replacement now @TRITON
Thanks ajs I am attaching two photos of the capacitor, as there is a lot of writing on it. it has a dia. of 25mm and as you will see from my original photo there is a white plastic cover on the electrical connection end, presumably to stop water getting on the connections. When it exploded there was all this sticky oil came out.Yes, it'll be a motor start or motor run capacitor. Personally I wouldn't worry too much about it, they do fail. Once failed the motor is unable to spin up which causes an overcurrent in the same manner as a stalled motor - that'll be what tripped the fuse.
Would you be able to take a picture of so we can see the label, ideally with a ruler alongside to identify the correct can size? Identifying a replacement can be problem matic but if you can source one from one of the electrical disties it's likely to be a fraction of the price of an identical "official" spare.
They often go with just a pop as the magic smoke contained inside bursts out. But the bigger ones can certainly go with quite a bang, more magic smoke = more pressure.Are we sure a capacitor is supposed to fail by exploding ?. My saw is a bit hesitant to turn on and im putting that down to a failing capacitor. I hope its not going to suddenly explode on me.
Not to challenge you but that Tormek has a threaded stud on the end for mounting. I don't get around much but every motor capacitor I have ever seen does not have that stud. Not a problem if the OP is decent enough at metalworking to be able to make his own clamp substitute. He might be stuck with ordering the original part.An identical is about £25 on eBay, or just get a generic 4uf (again work out if it's just start or start / run that you need) is about £4
