practise getting your tool firmly on the rest before making contact with the wood!
I'm going to start a thread of things not to do or stoopid mistakes.
oldsoke":2xpz9kny said:I'm going to start a thread of things not to do or stoopid mistakes.
There's an old but time honoured maxim in teaching... never teach the wrong method e.g. "don't do it this way..."
chances are that people will remember... and do it :!: :wink:
bwlossie":1xeyokl3 said:Once again, a "silly" question.....Spray with silicon. Is silicon furniture polish OK or are there additives which will clog up?
My daughter works for Pilkingtons in the USA, and says that silicones are not even allowed in building with the glass line, in case it prevents subsequent adhesion of windscreens formed from the glass.CHJ":3i4p51r4 said:Silicone is used as a release agent when moulding for this very reason.
If you ever try to repaint woodwork where the lady of the house uses liberal amounts of silicone furniture spray you will see the effect demonstrated.
dickm":1q2kjfqg said:My daughter works for Pilkingtons in the USA, and says that silicones are not even allowed in building with the glass line, in case it prevents subsequent adhesion of windscreens formed from the glass.
Typing the above I've just had another thought about those jitters - are they most noticeable when you're turning spindles? And sometimes they result in a 'wavy' cut that can be a real pain to correct?
