RodN
I have just bought a set of tool rests... the Sorby modular tool rest system, which I am using with my CCL lathe.
PROBLEM 1
With the tool rest pillar fully bottomed out, the top of the tool rests are 10mm above the lathe centre line. (I am able to set the "crude" CCL tool rest just above centre).
I appreciate that tool rest height is a "how long is a piece of string" question, but 10mm just feels way too high after using the standard tool rest. It feels as if I am pointing the tool much too far down. Bear in mind that I am turning pens down to about 10mm diameter anyway. It just feels so strange!
Am I being concerned unduly? Or is this just "normal"?
The only way to get the tool rest lower would be to saw some metal off the bottom of the pillar.
PROBLEM 2
Second question.... looking at a "normal" tool rest, the business edge is well forwards of the pillar. With the Sorby system, the fulcrum point for the tool is way back from the wood (exactly above the pillar). When turning smaller diameters, the main adjustment for the tool rest to wood distance is right in.... you just can't get it closer. Hence there is (I feel) too much potential for chatter.
Or am I being concerned unduly?
Rod
PROBLEM 1
PROBLEM 2
Rod
