gasmansteve
Hi folks
If you have one of the new condensing type boilers and experiencing problems with it working during the cold spell it might be that the condensing water drain pipe has frozen up causing the boiler to cut out. This pipe is likely to be a 22mm white or maybe black plastic pipe under the boiler which goes through the wall to a drain of some sort. A remedy for this is simply to run some very warm (not boiling) water over the pipe as it goes outside to melt the ice on the inside. I was on call yesterday and had 10 of the blighters :wink:
Steve
Steve
