StevieB
I have been using the Axminster CT150 6" joiner and 330 thicknesser to convert rough stock this weekend. Taking some 1" oak and bandsawing in half, a 5ft plank showed considerable bowing when cut - fair enough with thin stock and released stresses etc. Last time this happened I just ran the stock over the jointer to flatten one face, but given it is so thin you have to push it flat to the table to get it to pass over the cutter head, and when you release it you have a planed face but with the bow still in place. Same with the thicknesser, the rollers push the timber to the table, plane the face and the bow remains when when it comes out the other side. To try and overcome this, this weekend I tried shortening the length of the stock first before doing the jointing and thicknessing. Cut the 5ft plank in 2, to give planks of 2'6". this reduces the bow, but with 12mm stock still gives the above problems - going down to 9mm finished size I still do not end up with perfectly flat thicknessed stock. Its 9mm all the way down, but with a small bow still.
So is there any way to get perfectly flat thin stock - am I doing anything fundamentally silly? Can you only get it right if the original stock has no stresses relieved when initially cutting on the bandsaw so the rough stock starts of flat? Seems daft that you spen a fortune on 1" planks, only to cut them down and find they are useless due to internal stresses. Also seems daft to have to plane down a 1" plank a bit at a time from both sides to get a final 9mm plank - when cutting in half first then thicknessing gives me two 9mm planks.
since this is for a jewellery box, which will have a final length of approx 30cm, the bow across 30cm is minimal to negligable, but if I wanted a longer length at 9mm thickness it would be a problem. Just curious as to whether this is a common occurence, whether people just ignore it and accept it or whether I am doing something daft/have incorrectly set up tools/bad technique?
Any advice appreciated!
Steve.
Steve.
