Sgian Dubh
Here's an example. What you can see below is radially sawn Acer pseudoplatanus (Sycamore) and the flecking is the medullary rays intersecting the face of the wood. They are pale looking here, but that's just due to the way the light is refracted- if the light was from the other direction the chances are the flecks would appear dark.dickm":2g2thv13 said:I'm with Adam on this - it's beeck. Never seen those brown flecks on UK Acer species, but maybe Hard Maple does show them.
If you look at a tangentially sawn piece of wood for evidence of the medulla you need to look on the narrow edge to see them, so obviously if you're looking at a radially sawn board examine the wide face. It's harder to see the medulla if you look at rift or ******* cut boards because the rays are a little bit off from parallel with that face, and they generally intersect it at an angle, e.g., 5- 20º, but they're there if you look carefully. Radially sawn (aka quarter sawn), ******* cut and rift sawn boards are easily recognised because the pattern of the growth rings (spring/ summer growth) show as a series of parallel lines on the wide face of the board, as in this example. Slainte.
